  1. Member isogonic's Avatar
    Jan 2003
    @localhost
    hello, used vdub to check frames in a avi video,because tmpgenc kept crashing. got this: 2347 frames masked (25 frmaes bad 2322 frames good but undecodable, should i forget about making a VCD with tmpgenc?
  2. either chop out the frames (keyframe where it is located) with virtual dub or find a copy that doesn't have corrupt files in that section and swap the section in virtual dub. You will probably get sync problems or tpmgenc will error if you encode without repairing the file. There are a few pages on this web site that will tell you exactly how to repair files. With this small amount of frames I would just chop the keyframe that has the bad frames in it.
  3. Member isogonic's Avatar
    Jan 2003
    @localhost
    ok, thanks
    Mar 2002
    United States of America
    This guide should help with your bad frames:
    https://www.videohelp.com/forum/userguides/142555.php
    Hope That Helps!!! :P
