How do i get a .bin/.cue from an already burned SVCD?? I have an SVCD with menues already burned, but I want to turn it into a .bin and .cue file on my HD, how do I do that??
Thanks,
Papaholmz
For a bin/cue you would use CDRwin.
Go to extract sectors, and select the drive and output options for the files, and extract it.
You may also use Alcohol 120 to do this as well.
For a ccd image use CloneCD
an Nrg use Nero
etc
etc
Hope this points you in the right direction~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
If you need to make a CUE/BIN image of ANY type of CD (including S/VCD), then CDRWin is the way to go.
You can download a functioning demo here: http://www.goldenhawk.com
The demo is limited in burning but the extracting tools are all 100% functional.
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
