Here is what I'm doing. I'm burning 3 movies onto dvd. I'm using dvd workshop to build menus and author, but not to burn. Here is my process. All three movies are divx.
1. use virtualdub and save the wav file
2. Open the divx file in Tmpg and create a NTSC dvd project file.
3. Open tmpg project file with VFAPI and frameserve.
4. Encode with Cinema Craft Encoder
5. Convert the wav I saved in step one to Mp2 using Tmpg and toolame
6. Use Tmpg simple multiplex to join the encoded Mpeg2 from CCE and the mp2 from Tmpg.
For two of the movies, this process worked fine. However, one of the movies starts with the audio in sync with the video, then gradually the audio becomes out of sync and by the end of the movie, the audio is out of sync by about 3 seconds.
When I open the multiplexed Mpeg2 files with Mpeg Properties, all three movies bring up an error message that says "ERROR in audio packet header". This tells me that something is wrong with the way I am going about this process, but somehow the audio ended up in sync with two of the movies.
My question is where am I going wrong? What could be making the audio out of sync and how can I fix it?
I had bad frames in the original divx file. Fixed them using Tender's guide on the guides forum in this site, everything is okay now.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
.264 + AC3 Multiplexing problem
By 557953 in forum EditingReplies: 4Last Post: 24th May 2011, 09:16 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
