Hi All,
What are the Pros and Cons of using a small GOP size? I am using a mpeg2 capture board (Vitec DCM) and have noticed that when using the same source ( old VHS ) I get less mpeg artifacts when using a GOP size of 4, instead of the recommended 16.
Is there any problem using a GOP size so small?
Regards,
Jose Febus
no - as long as you user a higher bit rate .. the 4GOP is common in some high end mpeg capture boards to enable easier editing later on ..
but if you are capturing and burning straight ,, better to go w/ the standard GOP -
Do you have any idea why I get better quality in the palyback, using the same bitrate (5000), using smaller GOP sizes?
Regards,Jose Febus -
http://pwp.netcabo.pt/0165394101/Compression.html
Go down to the section that says GOP Structure
basically smaller GOP structures use less delta frames(those frames that are just calculated differences) and result in more I-Frames(those that are actually taken from the original). So in essence you have more of the original frames and less of the assumed differences. -
Hi all,
I finally got a viewable DVD from my Vitec DCM card. I had to configure it to capture using a GOP size of 4.
I think there is something wrong with the card due to the fact that I can capture usinf dv firewire connection and then convert the .avi to .mpeg using mainconcept whit a GOP size of 18.
Any Ideas?
Regards,Jose Febus
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
Move OS from small hd to a large hd
By mysts in forum ComputerReplies: 8Last Post: 24th Feb 2008, 06:17 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 19:48
