im adding subtittle whit vdub en then start a frame server and save the .vdr file
next im opening the .vdr file whit tmpgenc and it worked fine for about 5 times
now tmpgenc freezes or give's me the error (when opening .vdr)*the error acured when ACM was initialized * and if i press start again *illegal floating decimal point calculation order*
does anny1 know what to do about that??
or an other program that can use the vdub frameserver to encode to an mpg whit added subs???
a few days ago i formatted my pc just for the same reason
i think its really weird that it worked fine @ the beginning
thx in advance
issis
It is probably not the subtitles. If you are not using Virtual Dub's MPEG-2 version, it could be the AC3 sound causing the error. Does your computer have the Nimo Codecs installed? Have you tried to frameserve using a wave file instead of the AC3 audio in the AVI file?
Hello.
Can you use frame serving for video conversions?
By johnharlin in forum Video ConversionReplies: 2Last Post: 2nd Mar 2011, 22:39 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Frame serving
By carlmart in forum Video ConversionReplies: 2Last Post: 2nd Jul 2009, 08:39 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24 -
Frame Problems?
By kiyko in forum Video ConversionReplies: 1Last Post: 24th Jan 2008, 22:41
