  1. Hi,
    I was wondering if anyone could tell me how to rotate images during playback of an MPEG audio file? For instance, you can have one image displayed, followed by a music track. However, how can you get the image to change without stoping the music? Since tracks are sequential, I could only get 1 image per song, since to display another high res image would mean to skip the audio track?
    The only other solution would be to make a Mpeg with stills that change after a while, however I have no idea how one could easily do this from a set of JPGs or BMP files.
    Unless a program can string these images together with pauses, and encoded in MPEG for you.
    Thanks,
    Aug 2001
    San Diego
    Well, with software like Ulead Media Studio Pro 6.0 you can import images to be used in a video.
    I figure out how many seconds the song is, then figure out how many images I want to use, whip out the old calculator, and calculate how many seconds each image should be displayed for.
    Granted, it's not a one step process, but it works good, and with a little bit of effort you have a nice presentation. (by the way, this is what I do for a living. heh)
  3. WinOnCD 3.8 will let you create photo albums. Each album can have its own music track.
  4. But are the images hi-res? I'm beginning to think it is not possible to have audio with a hi-res photo image on vcd.
