I have an avi that wont delete. When I try to it it says it is being used by another program and wont delete it , even after restarting my computer. I've tried all of the registry hacks but nothing seem to make a difference. By the way I am using win XP Home.
Check this post out if you are running XP. It has helped me as it appears XP always wants to read the whole avi. I am also going to try it out on Win 2000 when I get home.
https://www.videohelp.com/forum/userguides/100406.php -
Just so everyone knows the problem was I didnt reboot after I played wth the registry, I just thought it didnt work. So I tried it again, rebooted and it worked.
I have this problem at times (yes, I am running Windows XP.) On my system dragging the file to the recycle bin does work, when other ways fail. I don't mean to insult you, but have you tried dragging the file to the recycle bin?
I don't know if this is related but I have a .RAR file that won't delete as well. Inside are DVD subtitles and they can't be extracted either. And no matter what I do, I can't delete the .RAR file! I run Windows 2000 tho.
Deleting files and directories
By Jomapil in forum ComputerReplies: 11Last Post: 20th Mar 2012, 06:41 -
Deleting cookies?
By neworldman in forum ComputerReplies: 3Last Post: 21st Jun 2011, 13:52 -
Deleting subtitles from videos
By angeloslev in forum Video ConversionReplies: 1Last Post: 23rd Feb 2011, 22:33 -
Deleting Audio Tracks
By cmars in forum AudioReplies: 2Last Post: 28th Apr 2010, 10:00 -
mkv - deleting multiple audio tracks & subtitles - then convert to avi
By fme008 in forum Video ConversionReplies: 2Last Post: 24th Mar 2009, 07:12
