Hi,
A little challenge for you all:
I want to create a computer system that will encode data the fastest, im not worried about cost - but be sensible. Dual processors - any advantage?
So, list the computer specs you would expect that could encode video and sound data the fastest.
JOhn
Are you really going to build a computer or are you just bored?
What's your budget?
Here is my dream system:
Lian-Li PC-76
Supermicro X5DAE
2 Intel Xeon 2.8GHz
2048MB nonparity PC2100 DDR
AIW ATI Radeon 9700 Pro
Soundblaster Platinum
3Com 3C996B-T 10/100/1000 PCI
Adaptec 39160 SCSI Card
Seagate Cheetah 73GB ST373453LW
Two Seagate Cheetah 146GB ST3146807LW
8Bank of 200GB WD drives w/HighPoint RAID controller
Plextor 40x SCSI CD-RW
Pioneer DVD-305S 10X SCSI
Plextor PX-504A 4X
PC Power and Cooling Turbo-Cool 475 XE/ATX12V
WinXP Pro
Exabyte VXA-2 Internal SCSI
I'll go w/SATA as soon as it's available with mobo. -
32 way Xeon, nuff said. A little chapers you can go 4 way Xeon that board is only about $1500. On the side of realisim you could build a nice dual Athlon setup.
Does dual help? Depends on what your encoding with... if it supports dual processors (like tmpgenc or CCE) then yes.
Resolved: Use Subtitle to Create Border on DVD Without Re-encoding
By sambat in forum SubtitleReplies: 6Last Post: 26th Feb 2012, 08:07 -
Create Menu's without encoding the video ?
By messi magician in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jan 2012, 18:20 -
Computer Encoding Box
By Clownzer in forum ComputerReplies: 11Last Post: 5th Jan 2010, 08:39 -
computer freezes when encoding
By persiani in forum Authoring (DVD)Replies: 3Last Post: 17th Jun 2007, 19:23 -
Authoring a VOB Titleset to create a Menu w/o Re-Encoding?
By Moontrash in forum Authoring (DVD)Replies: 3Last Post: 15th Jun 2007, 12:54
