I am looking at buying the cyberhome but can not decide whether the on the 402 or 505 i am only looking at playing dvd/dvd-r/+/rw and the occasionaly the odd vcds any body out there to which one i should go for
thanks in advance
sheppy124
Well m8 seeing as i'm using the Cyberhome AD-L 528 i can tell you that so far i haven't had any problems with it.
And as the 2 you interested are the newer version's from Cyberhome i can't really tell you how they perform.
I suggest you check out the following link....
http://forum.cyberhome-help.de/index.php
This is the Cyberhome forum for all there DVD players, there you can check on the Good and Bad of them.
But before you make your mind up, i suggest you give the Pioneer DV350s a lookup, you can now get it from www.richersounds.co.uk for £114.95 Multiregion.
Even check out all the other Multiregion DVD players on there website.
Then check them here to see what they play
phone to use in europe
By MJA in forum Off topicReplies: 3Last Post: 7th Nov 2011, 18:13 -
Closed Captioning in Europe
By Headway in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th May 2010, 10:10 -
How to stream US only video in europe?
By django56 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2008, 11:34 -
Do people in Europe use Hotmail?
By videobread in forum ComputerReplies: 44Last Post: 21st Apr 2008, 15:07 -
newbie archos 402 video question
By brucey2 in forum Portable VideoReplies: 0Last Post: 28th Dec 2007, 05:28
