Ok I did an episode disc with DVD2One. It plays in the player on my comp. When I put it into Nero and go to burn it it says
"Backup file VTS_01_0.BUP should be identical to VTS_01_0.IFO"
Is this a problem? Do I need the BUP file or can I just delete this? If I can't delete it what should I do?
I can't believe 61 people have looked at this and no one knows the answer. I thought I had the experts here.
I believe this program will make your VIDEO_TS file - just copy that IFO file to the BUP and they will be identical before burning. You'll have to ask inthe DVD2one forum on their website why the program possibly has a bug.
Panasonic DMR-ES45VS, keep those discs a burnin' -
Please wait a few days before bumping your post. This is no real time chat.
The bup file is a copy of the ifo file so it should be identical. Try move the bup file and make a new copy of the ifo file and name it .bup. -
When you do an episode you ahve to move the VOB's back to the original directory. WHen you use make it easy in step 5 you make a new IFO for these new VOB's. You are using the original BUP file though.
Do you need a BUP file?
Not the VIDEO_TS files. These have nothing to do with it. The VTS_01_0 files are what I am talking about
Can I just delete the BUP file? Or do i need it? -
You need it. Copy the IFO to the BUP.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 11:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 11:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 07:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 17:11
