Hey
I ripped A Knight's Tale to SVCD. I want to be able to compress it so that it fits onto an 80min cdr.
Is it possible? If it is, can someone tell me how to do it?
thanks
dangel234
it's possble, but most likely wll not play right because your kps will be so low that a vcd would look better and you dvd player would have trouble with the low biterate. I have found that you do not want to go past 60 minutes on an 80 minute cdr for svcd. I don't like to put a movie on more than 2 disks, so anytime that i cannot get a svcd movie on 2 disks, I make it a vcd movie (movies greater than 120minutes after i cut out the intro and the ending credits)
Compress movies in Adobe Premiere the same as Windows Movie Maker
By ckeen in forum Newbie / General discussionsReplies: 4Last Post: 13th Jun 2012, 21:11 -
How to crop the sides off a film like Star Wars so it fits my 16:9 tv fully
By marklittlevai in forum Blu-ray RippingReplies: 1Last Post: 26th Sep 2011, 11:27 -
How do I compress a movie (12.5gb) w/o losing much quality?
By aple in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 11:39 -
avs script giving me fits
By willmoodom in forum Newbie / General discussionsReplies: 32Last Post: 30th Sep 2009, 04:43 -
Is there any tutorial that fits a 1 Movie into 1 VCD?
By Rayster in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2008, 00:51
