how come everytime i leave my batch enc to encode at night. only 1 file in the batch encoded. and tmpg just close by itself when it finish that file? and not continue with the other files?
Klingon00
I didn't see an answer for this and I have the same problem.
If I run the file manually it also does the same thing. Log file shows it didn't encode but the files are all there.
Any other input on this?
Phil
[/b]
Canon Optura 20 for Video
Dell for Processing
TDK for Burning
Software? Looking for the Holy Grail -
Same problem here, post your computer specs:
Windows Xp + latest updates/patches/sp
Intel 2.4 Ghz
it worked before, now it closes itself. It does it with DV-avi files only. somebody here said, that the program works with DV type II,
+how do you convert from type I to II?,
+how do you know what type your file is? -
I don't know the difference between the DVI files. Is there somthing on this site to explain it?
The program does work for the first file, converting it and placing it in the proper directory. When I open it back up and look at the log it says that the conversion failed. The converted file works fine also.
My computer info is in the header.
Phil
Originally Posted by jgandaraCanon Optura 20 for Video
Dell for Processing
TDK for Burning
Same here, the converted file looks fine, but I can't do batch conversion. What I do it open encode one at a time.
, opening multiple times the program, encoding a different file on each session, it works but it's annoying.
I will check in other forums the DV type I and II -
Here is what I found.
http://www.puremotion.com/resources/technical/dvfiletypes/
Looks like the main difference is in the audio porition, so I am wondering if TMPGEnc doesn't like type 1 or 2 or if something else is causing it to close at the end of each file.Canon Optura 20 for Video
Dell for Processing
TDK for Burning
I found a solution. Go to the tools->codecs and get the canopus or DV 1 to DV 2 convertor (this last one is better) and convert your DV files to DV 2. Tmpgenc will digest them better.
Well I just found out that the second tool produce problems with audio. So be careful and check your file after is converted
X264 closing down
By asiafan in forum Blu-ray RippingReplies: 16Last Post: 6th Jan 2011, 14:13 -
AutoGK closing by itself?
By loveberri87 in forum DVD RippingReplies: 0Last Post: 11th Aug 2008, 01:26 -
Closing Multisession tracks?
By When in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 05:15 -
Compusa closing stores !
By SingSing in forum Off topicReplies: 49Last Post: 5th May 2008, 09:21 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 01:38
