  1. Has anyone got any good links for making multi movie dvds? also how long fits on a dvd if u've converted from svcd/vcd also whats the best framerate to use? everywhere ive looked says 120 mins but then how do people fit 5 hours onto a dvd, look at the lotr 2 / gony multi.
    if you could e-mail me, djork12@aol.com that'd be great
    ty
    dan
  2. Member curryman's Avatar
    Jan 2003
    http://www.kvcd.net/dvd-models.html
    i find the above templates for tmpeng allow you to fit 5-6 hours on dvd and depending on type of film (high motion or not) the picture isn't too bad, but don't expect dvd quality
  3. well,converting from a vcd i wouldnt expect dvd quality. does this work with movie factory?
  4. VCD's can be added to a DVD as-is except for the audio which has to be resampled to 48Khz.
