I have used Gold Wave to remove the pops and clicks using their filter and it worked well. What I need to know is how to remove the hiss and static without altering the sound drastically. I tried the noise reduction setting but got a new sound that sounded like someone talking through water. Anyone out there that can suggest how to do this in detail or possibly a new piece of software?
For all audio problems I use Cool Edit. For tape hiss use the noise reduction function. Make a selection with noise only and apply this to the complete audio. I've used it for all my vinyl to mp3's and now also for the audio part of my video's.
Good luck and regards,
Kees Janssen. -
I've used wavepurity to get ride of audio noise from video transfers. I use it primarily to get rid of noise due to tracking problems.
It works great and it is about $50. -
Sonic Foundry's Soundforge also has a Noise Reduction plugin that works pretty good...I have used it succesfully to clear up hiss from VHS captures.
Converting and removing noise/hiss at the same time
By Teac23 in forum Video ConversionReplies: 3Last Post: 21st Jun 2010, 12:35 -
hiss removal on a good quality VHS tape?
By zee944 in forum AudioReplies: 78Last Post: 26th Mar 2009, 04:28 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54 -
One problem after another (stuck tape in Hi8) Need help removing
By igotregister in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 19th Jan 2008, 12:32 -
Removing a block from a VHS tape
By dreamydiva in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2007, 22:12
