Done loads of movies in the recent past, but have a problem now.
Got a movie which I converted to SVCD using tmpgenc and it seems fine. However, its too big to go on one CD. I'm sure when I did movies before I just loaded the mpg (after conversion) into tmpgenc tools and split it.
I can load it into the merge and cut, but the slider doesn't function.
Am i going crazy cos I was sure I've done this before!! What have I forgotten to do?
thanks,
g.
reply to my own post, but to clarify, tmpgenc will cut the files if I manually type in the start and end range - seems to be just the preview that aint working.
WMV Cutting
By ajitpals in forum Video ConversionReplies: 4Last Post: 2nd May 2010, 04:13 -
[FR] Cutting TS Help Me Please
By KERNEL32 in forum EditingReplies: 5Last Post: 26th Feb 2010, 13:38 -
Cutting HD files
By surfer in forum EditingReplies: 2Last Post: 23rd Jan 2010, 13:06 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 08:32 -
Cutting Out
By OG24 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 18:55
