Results 1 to 11 of 11
    Jan 2003
    I'm running windows ME and i'm trying to use avi preview to check out my downloads from kazaa but when i try to run the priew i an error get message.
  2. WHAT ERROR MESSAGE ARE U GETTING???
  3. Are you sure it is an AVI file you are trying to preview and not an mpg.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You need to have a big enough chunk to process and sometimes that is quite large.
    For more info check out the website: http://www.avipreview.com/
  5. Videolan (see tools to left) seems to be able to play even small chunks of AVI files. If it gets to the end of the fragment, you will get an error message and it shuts down (can usually stop it before then).
  6. Originally Posted by Craig Tucker
    doesn't matter if its avi or mpg avipreview plays mpg and avi.
  7. Originally Posted by andybno1
    I have version 0.17 alpha and this does not support mpeg files.
  8. Banned
    Dec 2002
    Somewhere I belong
    The newets version which is version 0.21 can play mpg as well.
    You can get it from here:http://www.avipreview.com/avipreview.htm
    Jan 2003
    Cant seem to upload the screen shot to image at the moment to show the error, but i think ive worked it out it was just saying that the file was to small even though i had downloaded about 20mb.
    Just need to know do you leave the avipreviewer in the shared folder where the files are and do you need to rename them from dat to avi
  10. No, you dont need to rename the file you should be able to play the partially downloaded dat file. You can put avipreview wherever you like
  11. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    What'd I say?
