Can some one help when i rip a DVD I use smart ripper or dycryptor then depending on the size of vobs i use infoedit to remake info and bups and if the vobs are to big i use dvd2one then i use neroexpress to burn back. the problems is that in the rips only play back on my old unhacked pioneer and will not play on my tredex or medion player which have been totaly hacked to region free /macrovision. I have also use a ripped film that use to play on my tredex ripped to hd made new vobs burnt it back using nero and the rip wont play on tredex bit it will play on old pioneer and even the PS2.
Just to let u know that it was nero that was at fault bad template used recordnow that seems to have solved the problem
Can a PS3 play Blu-Ray region free dvd?
By Minx4MadMen in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Nov 2010, 19:15 -
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 19:48 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Can't play PAL dvds on my region free player anymore
By bubblefaerie in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th May 2008, 10:51 -
LG LH-D6246 region free some disks wont play
By sydneyozguy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Feb 2008, 21:25
