I am trying to rip a dvd using dvdx. I have been using one of the guides which is on here. I have dvdx but I do not know where to get the panasonic plug in. Also once I have it where do I put it ? and what does the file extension look like.
Also where have all off King John's guides gone ?. They are really helpful.
You are referring to the commercial Panasonic MPEG Encoder Adobe Premiere plug-in version.
You can find the demo and on-line purchace details here: https://www.videohelp.com/tools
As for KingJohn's guides, he was banned and he requested his guides to be taken down.
Regards.Michael Tam
w: Morsels of Evidence -
Good luck trying to get the Panasonic plugin to work with DVDx. I've tried every which way and still can't get it to work. DVDx encodes about 6 frames then stops. If you figure out how to use it let me know!
Don't know about DVDx (I don't use it), but the Panasonic MPEG encoder plugin works brilliantly with FlaskMPEG.
IMHO, the Panasonic MPEG encoder creates the best quality (on average) MPEG-1 video at VCD settings. TMPGEnc is pretty good too and many people consider it to be the best ... but it doesn't come in the form of an Adobe Premiere plugin...
Regards.Michael Tam
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 13:37
