After trying a wide format of video capture settings, I was getting frustrated with the fact that several programs would not begin to process my video files. However, when I switched the audio to direct copy (no compression), everything worked fine. Since this is happening in different programs, I'd assume there is something wrong with my audio compression files.
In VDUB, for example, I used several different compression codecs including divX audio, MP3-audio, and Windows Media, all giving me the same problem (VDUB would open up the processing window, compress the first batch of frames and then stop indefinately).
Anyone heard of this problem, I'd really appreciate some help, or simply how I might go about repairing files pertaining to general audio compression. Thanks.
Have you tried the Virtual Dub MPEG-2 version? It is supposed to support AC3 as well. Look in the Tools section.
Hello.
Program / Plug-in to identify TBC errors (but not correct them)
By robjv1 in forum Newbie / General discussionsReplies: 16Last Post: 11th Feb 2011, 19:44 -
Best compression program/format/codecs without losing quality
By adrian2055 in forum Video ConversionReplies: 12Last Post: 20th Jan 2011, 16:29 -
YT audio compression
By -Sandro- in forum Video Streaming DownloadingReplies: 0Last Post: 26th Oct 2010, 08:25 -
Audio Compression
By Nitro89 in forum ComputerReplies: 8Last Post: 2nd Oct 2008, 10:00 -
Best Compression program
By natty in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 20:10
