I've been creating CVD's with Tmpgenc and they always burn with Nero. However any CVD's I create with CCE 2.66 will not burn with Nero or VCDEasy. Both of these apps inform me that the CVD is too large for a cd.
The CCE mpeg in question is 725 megs. Both Nero and VCD tell me it is too large. Yet I've burned 800+ meg Tmpgenc CVDs with Nero...
And yes I know they are not SVCD compliant and this is NOT the problem I'm having.
The 725 meg CCE mpg will show well into the read area in Nero (bar that indicates amount of cd space used) YET the 800+ meg Tmpenc does not show into the red.
I tried creating a VCDEasy bin file, but upon completion it informs me it is too large for cd media. I can not burn this bin file in Nero as Nero tells me it is too large as well.
What gives ?
Originally Posted by kenmo
Why don't you try to correct it in TMPGenc (MPEG tools)
Open the simple multiplex menu, load the file in video. In the audio and in the output fields let the same file.
Then choose MPEG-2, SuperVideo CD.
Press Run.
Let me know if it helps.Best wishes,
UP -
Are you trying to burn it as a DATA file and not an actual svcd.. remember data capacity only 700mb per cd, SVCD capacity 750MB plus??
Sounds like a wrong header.
Press Run.
Thanks muchly...I tried as you suggested and I was able to burn the mpeg to a cd.
Cheers
Kenmo -
Cheers
Kenmo
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
LG GH22LP20 16X won't burn at more than 2X
By BeyondInvisible in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Feb 2009, 13:55 -
Burner won't burn DVDs
By Nephilim in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jan 2008, 16:23 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 21:06 -
DVD Won't Burn
By wwpranma in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 03:32
