I tried just saving it out with direct stream copy and, like I thought, when I load the new file into regular VirtualDub, it still gives the VBR warning.
Results 61 to 80 of 80
Originally Posted by videocheez
I followed your idea but still the film is out of sync. A while ago I encoded this film and because of these problems i burnt into onto 4 vcd's. Each VCD finished before an error and the new one started after. In this way no parts were out of sync. But now I'm attempting to do this all again but onto one DVD. If I create 4 mpegs again and join them all up will they be out of sync (I've never tried this before!).
Thanks again. -
follow the guide(as if you did have bad frames),then do the direct stream copy for both audio and video,then save out as new avi.Originally Posted by lordkinbote
That's what I'm saying. I opened the avi, checked for video freezes, it found no bad frames and there was nothing in the log to correct or delete so the only thing left, according to the guide, is to save the avi out using direct stream copy. I took the NEW avi that was made, loaded it into the regular version of VirtualDub and I still get the VBR warning. Am I overlooking something?Originally Posted by tenders
strangeOriginally Posted by lordkinbote
i have done it this way in the past, and also like you did,check with the regular vdub afterwards,in my case the vbr warning was gone. have you actually tried encoding the file,or are you guessing that it will go out of sync
if it is in sync as an avi,try loading the file into tmpg,as is,then encode it and see if this works.
well, I already tried encoding with TMPG first and they became out of sync but that was when I encoded them with wavs I saved out from VirtualDub. That's why I looked here for a possible solution. I didn't try it with getting both the video and audio straight from the avi, but I figured if it did that from a saved out file, it wouldn't do better straight from the avi although, who knows?
Yes, the original avis are in sync. -
strangely enough, just encoding the video and audio straight from the avis kept them in sync. I assumed, as per past experience (from the first two avis in the series among other things) that it was because of the VBR that made it go out of sync so I would always save the wav out first and it would be fine. But, it seems in the later avis of this series, it's better to just encode them normally.
Everytime I try to run the "Check Video for Freezes" option, VDub-MP3 freezes and gives me an error.. The error states "VirtualDub has crashed due to a program error."
Has anyone else ever experienced this problem?
Thanks!!! -
Yes, corrupt frames can cause all kinds of problems. If you know where the problem is then you may be able to edit out the bad frames with Vdub.
"Art is making something out of nothing and selling it." - Frank Zappa -
I have a similar problem with a divx freezing with tmpenc and used vdub mpeg to check the frames but there are no bad frames. I have raised the priority of the Direct Show Multimedia File Reader but that has not helped. Any suggestions please ?
I have created a small program to automate this process to remove bad frames. It only runs in windows. It was created using the dot net framework (available from Microsoft).
These is how it works:
+ Enter the name of the video file, the location of the error log
+ It will create all the steps needed for virtualdub to do the cutting, based on the bad frames, it analizes the log file and decides what frames to remove.
+ You can execute the steps, what I'm doing is sending keystrokes to virtualdub to do the editing, so you will ned to leave your computer alone.
If anybody is interested, let me know.
It also let you select a list of files, and you can automate it to select each file, and add it to the job list. Here you can get errors of compatibility, but at least you can select multiple files and do it automatically.
This program is pretty rigid, it works as if you were entering the keystroks, so if an error message show up, it's certain that you won't get the results u want. -
Anyone following this outdated guide listen here:
This is a very long process. It takes forever to scan the file because it logs almost every damn frame in there. You ened up hacking away too many frames. I have a better solution that works for me every time.
I just load up the avi file in Virtualdub MOD....choose NO for the vbr warning because it alters the file. The choose 'scan errors'. The time it takes is far less than vd mp3 freeze. Once done it will show if there were any bad frames at the bottom of the main screen. If so, go back to the 'scan errors' box and notice 'show bad frames'. Click it. It will list the bad frames, write them down. If there were no bad frames you have 2 options, either believe there were no bad frames OR try the method above. Sometimes virtualdub doesn't see 1 error that was present and that one error can throw off the audio. The best thing to do is, if there were no errors found, then set the audio to FULL PROCESSING and the video to DIRECT STREAM and save the new AVI. Then play the file in a media player and skip to different parts of the move all the way to the end to make sure the audio is in sync. I always do this with every file I create just to make sure. If the audio is off in the middle it will be off all the way to the end.
If virtualdubMOD found errors then look at the first bad frame you wrote down and choose GOTO and put in the first bad frame and click ok. Then click the MARK IN button. Then GOTO then next frame you wrote. Click NEXT KEYFRAME button and then click MARK OUT. Then go up in the menu and choose DELETE. This will wipe out the bad frames as well as the audio with it. Do the same with every bad frame you wrote. Once you are finished then choose FULL PROCESSING audio, and DIRECT STREAM video and save the new avi.
NOTE: Don't close out MOD just yet. Check the new file to make sure there are no sync problems. If there are then delete the new file and go back to MOD to do some more. Sometimes Virtualdub will see an error but will miss a bad frame and list the following frame, FOR EXAMPLE: frame 26987 may be in the list when 26986 may have been bad. This can still cause a problem. What you can do is move(or GOTO) a point alittle ways before each bad frame you wrote and then play the file within MOD(or use the scan buttons) and you can visually spot a problem a frame at a time.
Hope you get it.
I have had to do this to so many crappy encoded avi's but i always end up with a perfectlt encoded SVCD. -
if you don't like my guide,then why not write one of your ownOriginally Posted by cooljoe666
however,this thread is not the place to do it
Where is the program v-dub MP3 Freeze?
I can only find links to the vanilla non-modified version of V-dub.
Thanks if anyone has it. And what happened to it?
email: kewl_guy@hotmail.com -
Originally Posted by bep1291
you can find it here: https://www.videohelp.com/tools?tool=73#comments -
Or here
http://www.movieking.yourhobbies.co.uk/files/index.php?action=file&id=4
where this guide was ripped from
Signature removed.
/ Moderator Cobra -
in this post hasnt it missed the bit about masking the bad frames and also i used this guide down to a t and it still crashed tmpge xpress during encoding. just trying to get my head round this as there are a lot of films available with bad frames more the pity...
i have never used this with tmpg xpress. i would recommend trying the regular tmpg or the plus version.Originally Posted by dexyweescot
does it make any difference if u do both scan for unreadable frames and freeze frames in both versions...
im going nuts!!!i read a lot -
Unfortunately, this method doesn't do SQUAT to FIX the VBR problem - the direct stream output of both video and audio still leave the audio in VBR!
Ah, well - now I know how to get rid of the freeze frames at least - and thanks for that!
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 02:49 -
Bad condition tapes, causes capture freeze
By devoid in forum Capturing and VCRReplies: 12Last Post: 15th Sep 2008, 13:57 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 26th Aug 2008, 00:59 -
Joining Xvid files with MP3 audio (VBR) without loosing synch?
By fk in forum EditingReplies: 6Last Post: 31st Jul 2007, 20:19
