I've had 5 TV tuner cards.
2 ATI All in Wonder VE-The picture from any non cable source looked so crappy n flickey it was unuseable.
2 Pinnicle PCTV cards-Neither would play audio for more than 1 minute
2 AserTV cards. I'm on the second one.
The problem now is sometimes it'll loose the signal n i'll have to change the channel to get a picture. Also the sound fades out sometimes. I have updated the drivers and software.
Someone help me
My system Specs are (use these, not my profile)
P4 2.4GHZ
400MHZ front side bus
80 Gig HDD
512 Ram
Windows XP home
Intel Graphics Card
Asus motherboard w/ intel graphics set.
System is all up to date
3 PCI ports, the card is on PCI one. The system supports ACPI.
On anouther note, did anyone have trouble fitting the card into the system. I had to almost force my card into the PCI slot.
Is your power supply beefy enough for all peripherals? Is your TV signal strong & clean? Eat your veggies?
Panasonic DMR-ES45VS, keep those discs a burnin' -
The power supply is powerful enough.
The signal is a CATV signal so it's fine.
Corn, Braccoli and Green Beans. -
Hmmm - since you've had so many cards I think we can rule out bad cards.
Digital cable into an analog card? :P
Maybe try a small video amp on the cable - try to get a nice clean signal? Radio Shack would be a good bet there.
You could have a DC offset on the cable. Or more likely a ground loop between the cable jacket and the PC case. RS has an inline DC block also - a voltmeter between the jacket & case would tell (try DC and AC).
Last chance - move down to Virginia
Analog Cable, we don't have the moneyt o pay for digi-cable.
I'd rather have cable net than digi-cable -
Have you tries differant PCI slot? Didn't over tighten cable to card? Cold solder joint on card?
Had bad solder joint on a TV Tuner card b4.May the force be with you.
DVD recorder digital tuners
By joecass in forum Newbie / General discussionsReplies: 80Last Post: 19th Apr 2011, 12:51 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 06:39 -
TV Tuners in Windows 7 x86
By jznomoney in forum Capturing and VCRReplies: 0Last Post: 10th Aug 2009, 17:44 -
QAM Tuners
By hd999 in forum DVB / IPTVReplies: 3Last Post: 23rd Dec 2007, 20:29 -
HD Tuners
By sponge in forum Newbie / General discussionsReplies: 7Last Post: 22nd Dec 2007, 05:21
