when encoding with the tmpgencoder,trying to convert divx to mpeg i get an error message stating illegal floating decimal point or illegal floating decimal point.what exactly is that and how can i fix this problem?
To get ride of this problem you need to set the VFAPI plugin settings in TMPGEnc.
Open TMPGEnc select options in the tool bar at the top select Enviromental Settings, There should be 5 tabs select the VFAPI Plugin Tab you should have a list of plugins make sure Directshow Mulitimedia File Reader has a priority of about 4 just select it and right click the mouse selecting higher priority. I would also make sure that AVI2(OpenDML) is at priority 3 this should solve the problems also make sure you have the codecs installed for DivX try to avoid the Nimo pack, im sure many will curse me but they are a bit tricky when they want to be. You can find links on this site under tools to the left of you Make sure you haveDivx 3/4/5 and the XviD codec you may have problems with XviD this site has good solutions if so. Take alook at the DivX to SVCD guide to avoid making lots of coasters your your cups.
Hope it works!!!!
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31 -
Newbie question on Capturing to Encoding
By Lucky19th in forum Newbie / General discussionsReplies: 10Last Post: 16th Jul 2007, 14:09
