  1. DVD decrypter did not automatically select the following files:
    video_ts.ifo
    video_ts.bup
    vts_01_0.bup
    When I tried to burn the dvd2one transcoded files, Nero threw up a warning message that the above files were not available. BTW, I am using the Video DVD burn option in Nero. Rather than try burning the files, I just ran DVD decrypter again and manually selected these files. DVD decrypter did select these files for another DVD I was backing up. Is there a reason why DVD decrypter did not automatically select these files in one case and did in another? Do I really need them?
    For one DVD backup, the DVD decryptor selected files only took up 3.55GB, but after DVD2one got through with it, it was only 2.9GB. Why did DVD2one needlessly remove data. Is there another way to transcode that would not shrink the files size down? It seemed like the audio level was lower when I played the DVD2one transcoded files through PowerDVD compared to the DVD decrypter files.
  2. First, DVD Decryptor while in "file mode" will only select the main movie files. You need to hold the "Ctrl" key down and select the other three files yourself. Then rip them ALL to the hard drive. Since you already have the main movie files, just select those three files seperately, and it will take less then a second to rip. Then do your procedure again. It sounds like you did just that, but just keep that method in mind for future reference.
    It does? I've used DVD Decryptor on about 100 movies, and it hasn't selected those three files on ANY of them as of yet. You must have an enhanced version. I am joking of course, and i'm sure the files weren't selected automatically. You have to select those files manually. Anyway, as far as your file "shrinkage" goes, I have only used DVD2ONE for some tests, and I personally won't use it. But to answer your question, from my understanding, DVD2ONE will NOT transcode if it doesn't have to. Meaning that in your situation, what probably happened was that DVD2ONE stripped out some extra audio tracks or subtitles which you didn't select, and the result was a file of 2.9 GB's. You can always use IFOEdit in that situation to make new .IFO files and keep all or none of the subtitles, and only one or all of the Audio tracks, as long as the total file size is under 4.37 GB's, you will be ok. Good Luck
  3. You don't need those files before transcoding with DVD2One because it will create new ones during processing. Just load into DVD2One what DVDdecrypter selects by default in File Mode.
