i got this error in scenarist after trying to import my movie made in adobe premiere using the lsx-mpeg plugin for premiere :
Error
D:\DVD\Dolly\dolly.m2v
Error : Number of fields (158444) in GOP(# 1) or between
sequence_header_code should be equal or smaller than 30.
could someone explain this ?
thanks.
It has been a while since your post and perhaps you have found out a solution to it. In case you haven't, the answer is:
DVD specs require GOPs with up to 30 frames per GOP. This means you must have control of the encoding process, something I don't know if the lsx filter allows.
Additionally, MPEG encoders are not made equal. CCE and tmpgenc are the best out there and they both allow you to have fine control over what they are doing. I would suggest using one of these.
In case you choose tmpgenc, there is a guide in VCDHelp.com that explains how to encode to DVD standards (and the templates will help you get started).The more I learn, the more I come to realize how little it is I know.
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 13:06 -
Scenarist 4.3 subtitles problem
By paulspurrier in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Jun 2009, 06:16 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 05:38 -
Scenarist Menus
By nx01rules in forum Authoring (DVD)Replies: 5Last Post: 11th Nov 2008, 00:22
