I'd like to capture footage etc from cable TV and old home movies from VHS.
I've successfully captured before but i'm not sure if i'm using a much higher bitrate then neccessary,the footage i'm capturing isn't very good compared to that of a DVD but if I go too low the original poor image will be emphasized and look worse than the original.
I'm using a Sony Handycam with its pass-through capability between a VCR/cable TV decoder and the PC via fierwire cable.
What is the best codec to use and how many MB per second (bitrate) should I use and what image size? most footage is full 4:3 screen but some is 19:9 i'm not sure what the actuall sizes are but they must be compatible with an eventual DVD copy.
I'm in a PAL country.
I have many codecs to choose from but which is the best?
I have Ulead MediaStudio Pro 6.5, Ulead VideoStudio 6, Adobe Premiere 6.5 and Windows Movie Maker.
Hope you can help,thanks in advance.
Results 1 to 1 of 1
Looking for Low Cost (Cheap) Stock Footage for Editing Production
By HoosierGuy in forum EditingReplies: 3Last Post: 13th Feb 2012, 06:07 -
DVD footage with low volume CAN WE FIX IT ??
By rockonvidtrade in forum AudioReplies: 7Last Post: 11th Jan 2010, 12:27 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
Capturing footage-problems ...
By perik in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 7th Dec 2008, 18:11
