Alrighty, I was having problems with TMPGEnc, and someone suggested that I download TMPGEnc first and then download the nimo codec pack. Well I downloaded TMPGEnc first and it worked, but then when I downloaded the nimo pack an error message comes up (which I have listed about before). So now I cant use TMPGEnc because of the nimo pack, and I am only using the video and audio codecs from the pack. I dont know what to do, I hope someone can help me.
whatever happens, happens......
Installing the nimo codec pack is never the answer. It causes numerous problems and to tell you the truth, I have never actually talked to anyone who used it without problems. Uninstall it and simply install the codecs that you use. Get the latest version of the divx codec and you might want to pick up the AC3 codec in the tools section as well. If you deal with mpeg2 (DVD or SVCD) than install a software DVD player, any trial version will do. Most other codecs will automatically download when you try to play them in WMP.
can't get ut codec to work in win7-64 with vegas10-64
By aedipuss in forum Video ConversionReplies: 0Last Post: 6th Oct 2011, 17:27 -
Codec won't work with Vegas
By Jon.G in forum EditingReplies: 1Last Post: 26th Sep 2011, 07:52 -
Proxy codec for remote work?
By Taapo in forum EditingReplies: 28Last Post: 11th Aug 2011, 14:56 -
Best AVCHD codec that will work with Vegas?
By The111 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Nov 2009, 21:54 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40
