I usually use DivX 5.02pro for simple low-res caps ( noise reduction realtime...well, kinda lazyand my tv has lot of noise).
Two days ago i dl'ed and installed DivX5.03PRO (ad-ware version), and
now, when i try to select "quality"-based mode (in vdub) it's crashes (first - it say's smthng like "value too high", then locks up PC).
Unf. have no time for reinstalling OS, so switched back to 5.02 for now....
Any ideas?
When I installed DivXPro 5.03 the "1 pass quality based setting" disappeared from the dropdown menu!!
I don't think 5.03 has this setting.
So your 2 installs may have mixed, so that you see the option but it is not available.
I have returned to 5.02 now.
Fozzee -
hi guys,
1 pass quality setting most definitely is available in 5.0.3. you have to de-select the 'Choose your profile' from the profiles tab. hope this helps
cliffo
Dr. Divx Crashes
By GrayStrickland in forum Video ConversionReplies: 1Last Post: 1st Apr 2009, 12:43 -
Simple DivX: Crashes with Mencoder Error Every Time
By CobraPilot in forum DVD RippingReplies: 5Last Post: 10th Jul 2008, 20:47 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 07:38 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40
