I used TINRA to convert a 34Mb .rm file to a 2Gb .avi file.
Now I'm useing VirtualDub according to the conversion HowTo on this web site. I notoced it saved an avi file at 16Mb but it's never changed file size. It's been going for 20hrs so far.
Also I noticed that in the VirtualDub main window it says "Dub in progress" but the percent always stays at 0. The pop up window shows the following info:
Current Video Frame: 0/10623
Current Audio Sample: 8192/58013983
Video Data: 0 Bytes
Audio Data: 0 Bytes
Projected File Size: Unknown
Video Rendering Rate: 0.0fps
My machine is an AMD Athlon T-Bird running at 1.2G/26FSB
PC-133 512Mb RAM
Thanks for your time
You may not have a proper avi. I believe there is a filesize limit to avi files of 2GB. Maybe Tinra quit producing an avi because it reached 2GB. VirtualDub may choke on this avi.
This may be the cause I don't have a solution I'm afraid. Hope this helps you though.
Regards,
Willem
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Editing video in virtualdub taking so long!
By admirer in forum Newbie / General discussionsReplies: 14Last Post: 8th Apr 2010, 13:43 -
A long overdue thank you
By epj16706 in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2008, 21:03 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 19:08 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
