When I try to apply chapters to my vcds' with "vcdeasy" a message informs me that the maximum number of chapters possible is 1. I've looked round the different options to no avail. It normally works fine so I'm a bit confused.
Cheers !
When you create the MPEG video stream you should verify if you include GOP sequence headers. If you use for example TMPGEnc then you should choose in Settings-> GOP tab a value greater than 0 in Output interval of sequence header.
Jürgen
AVStoDVD Chapter Problem
By adyf in forum Authoring (DVD)Replies: 11Last Post: 21st Dec 2010, 14:03 -
mkv chapter file problem
By Bully9 in forum EditingReplies: 12Last Post: 22nd Mar 2010, 18:06 -
Muxman problem with chapter times
By lordretsudo in forum Authoring (DVD)Replies: 12Last Post: 9th Jan 2010, 07:52 -
VOB2MPG Chapter Extraction Problem
By murray666 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Oct 2009, 03:14 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 11:51
