I will try to explain the problem as best I can .
This is what I'm burning to disk: Mpeg Still (Intro)
Mpeg Movie (Main)
Mpeg Still (Insert Disc 2)
After I have done all this everything plays perfectly in Power DVD, WINDVD etc, But when I play it in my Standalone all that plays is the main movie and no stills. Anybody any idea of what I am doing wrong.
Regards: Patsym1
Bug in the generated bitrate!
Sorry, stills converted by VCDEasy's multiplexer have too much bitrate.
Most of standalones cannot display these pictures.
A generated 704x576 still has normally 50-60 kByte size at a bitrate of 9800 bit/s, not more. It seems MPEG2 is more sensitive as MPEG1.
I generate my stills with TCV 0.84 with a limit to 56 kByte. These pictures played on all standalones.
You can generate stills with TMPGEnc to see what size they should have at max bitrate 9800 bit/s.
But this stills have not the right stream parameter E1, and don't play on VCD.
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
dvd/mpeg problem
By 557953 in forum EditingReplies: 4Last Post: 1st Feb 2009, 15:15 -
Will the QT MPEG-2 Playback addon help my no MPEG audio on vegas problem?
By Nuke Shower in forum Video ConversionReplies: 5Last Post: 9th Apr 2008, 16:01
