  1. Which mpeg encoder is the best for encoding DVD files into mpeg(VCD format) files?
    I have panasonic but it has a mediocore quality...
    Feb 2001
    Berlin, Germany
    Taste is subjectiv, you know. Panasonic and TMPGEnc are supposed to be the best MPEG-1 encoder for VCD.
    If you are not satisfied, consider to make SVCD. Here is CCE the best.
  3. For MPEG1 TMPGenc, for MPEG2 CCE. If nothing else CCE's 3-5pass VBR allow you to use really low bitrates and get near DVD quaility encodes (for a good source of course )
  4. Are there any good mpeg codecs for encoding vcds?
    Feb 2001
    Berlin, Germany
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    http://www.vcdhelp.com/vcd.htm
    http://www.vcdhelp.com/convert.htm
