how do u add sound to a menu???
You can use Ulead Movie Factory1 or 2, add music for one or more menus, it's great.
I used to be intimidated by menus, especially because you need them to properly backup those multi-episode DVDs (Sporanos, Sex & the City, Band of Brothers). I found that DVDMaestro is exceptionally easy to do both the menu background, buttons, and sound . . . simply import the background and sound, drag your backgound to the menu template, drag the sound on top of the background, draw your buttons and map accordingly.
Adding new M2TS file to existing bluray with menus intact
By tanzer26 in forum Authoring (Blu-ray)Replies: 6Last Post: 25th Jun 2012, 07:45 -
adding menus
By tfrost2002 in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2011, 15:10 -
Adding menus to a remuxed Blu-Ray
By ITISRAVI in forum Blu-ray RippingReplies: 0Last Post: 17th Nov 2010, 09:27 -
Adding subs to DVD (keep menus) - CONFUSED!!!
By ZQX in forum SubtitleReplies: 8Last Post: 11th Aug 2008, 03:18 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 01:05
