Everytime I capture the colours are always annoyingly saturated. Particularly whites, in many scenes one's cloth would blend with the wall behind (can't distinguish between the cloth and the wall anymore).
This heavily degraded the picture quality.
Anyone can help or is this card is just dirt cheap that I should expect nothing from it?
Thanks in advance
Unfortunally this reply will not help you with this issue. I too have the same problem and have not been able to figure out what to do about it.
I have several VHS tapes which contain images taken from 'very old' family 8mm films. When I try to capture these VHS tapes through my ATI AIW card I get very poor quality results with parts of the capture almost completly whitewashed out.
I you learn of any possible answer regarding this problem, please post.
Thanks,
rfos
Blackmagic Intensity Pro PC to PC capture problem
By Epero in forum Capturing and VCRReplies: 7Last Post: 18th Sep 2010, 08:43 -
Lowering color saturation in Final Cut Pro
By Huntr777 in forum MacReplies: 4Last Post: 22nd Oct 2009, 11:03 -
pixelview tv capture card
By oldboy29 in forum ComputerReplies: 1Last Post: 5th May 2009, 17:42 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
Pixelview capture card under XP
By Greycat in forum Capturing and VCRReplies: 8Last Post: 23rd Apr 2008, 15:11
