I have made several VCD's from DVD's and AVI's but somehow only my TV's right speaker gives sound even though I made a stereo Mpeg. The strange thing is that it has stereo on my PC, the sound coming from my DVD to my HIFI-set gives stereo but my TV doesn't. When I select channel B in the multi-language menu on my TV it gives sound through both speakers but I guess this is mono. What am I doing wrong? I tried all the different audiochannels in Tmpgenc but this this also makes no difference. My TV is a Sony Widescreen which is one month old.
The video you are about to burn into a VCD, can it be loaded into Gold Wave? If it can, do it and see if both audio channels are present. If not, you can copy one channel and Mix it onto the empty channel and save it. The use it in TMPGEnc as audio input to make you VCD file.
Hello.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 18:06 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 12:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42
