    Feb 2003
    Texas
    I have a question about authoring (s)VCDs in Windows XP Pro .. i dont know if you know the answer but im desperate.... I just upgraded from Win98 to WinXP (i know clean install would be better) i have made numerouse VCDs with Win98 and they worked great, since i have upgraded none of them play in my standalone player... they will only play using windows 98 i have used every software program from Nero, VcdEasy, EZCD creeator.. ect.. used all the ASPI drivers.. i cant seem to figure out why i cant get it to work...
    Feb 2003
    Texas
    havnt changed burner or speed i burn at a very low speed... i have one of the first cd burners they put out for the public to buy and afford... it only burns at 2X so its probably not the speed... umm.. what i have tried it burning the exact same video on the exact same media on both windows 98 and windows xp just different computers... its worked with 98 and not with xp.. im not saying XP is really the problem.. but since iv upgraded it hasnt worked.. it burns data fine.. it actually even burns the video on the cd and works on my PC but not on standalone player... when it did using the exact same computer with Win98... i dunno.. its weird to me.. thanks for the help!
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Did you change anything else? New burner? New CD-R's?
    Do they play OK on your system? On another player?
    Have you changed burn speed? Lower is better for some people, you might want to try it.
    Just a few thoughts.
