Hi Guys,
Wonder if any of you genieues can help me, let me tell you my tale of woe, I have been converting DVD's to SVCD a while now using DVD2SVCD with very sucessful results.
I have just obtained 4 DVD's containing Espisode of the old UK TV Series called The Professionals, each DVD contains 4 Episodes.
IO have ripped each Episode sucessfully using Smartripper tahn then I am performing the conversion using DVD2SVCD, on each DVD the first two Episodes convert fine, however, when I try and convert the third and fourth episode, DVD2SVCD just freezes after a couple of seconds, I usually get a separate Windows running DVD2AVI but this does not start.
Can anyone please advise what is wrong and how to rectify the problem or can anyone recommand a better way of performing the converion.
I like DVD2SVCD as it does everything in one program.
Should be getting a DVD burner in a couple of month so that will be a help but that does not solve my present problem.
Thank you in anticipation of your help
Pat![]()
Results 1 to 1 of 1
