I usually use virtualdub to rip the audio of TNG serious. usually i use full processesing mode, cause i get these vbr errors. in season 4. when i ipen the avi i dont get the vbr error. so they won't let me rip the audio in full process. instead I have to do it with direct stream. now after buring the movie i would hear these skits sound in the movie.? anyone know how to fix this?
Originally Posted by Klingon00
Originally Posted by bugster
i get this error when doing full processing mode
"The requested audio compression is not compatible with the input format. Check that the smpling rate and channel count of the input match those of the requested format". -
You have a missing audio codec. get gspot and it will tell you exactly which codec you need (its probably Ac3!).
ok. i found out that its ac3. that explain why it said in the file information that the audio is unknow and 2 channel.. but the quality of the sound after encoding sound horrible. anything to make it better? or make it 5 channel? after using virtual dub i use headac3he.
Ok so let me guess, you extracted the audio from the avi with vdub using direct stream copy and converted to wav or mp2 with headac3he. Is that about right?
If that is what you have done then I don't know of any way to improve it, sorry.
What sound effect am I hearing?
By takearushfan in forum Newbie / General discussionsReplies: 5Last Post: 4th Jul 2010, 21:16 -
Error in Variable bitrate (VBR) audio detected
By Russo in forum AudioReplies: 9Last Post: 12th Feb 2010, 08:01 -
Need help with virtualdub error involving VBR encoding
By Hark in forum EditingReplies: 16Last Post: 11th Feb 2010, 23:45 -
VirtualDub 1.8.6 = Error about Audio (VBR) ??
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th Oct 2008, 10:55 -
How to remove hearing impaired subtitles from idx/sub format?
By Talayero in forum SubtitleReplies: 6Last Post: 3rd Sep 2008, 11:40
