OK..I have a protable VCD player and I have a lot of divx, vcd & svcd movies...and I have 100s of questions![]()
1. since I'm from Europe..do I have to make PAL VCDs?
2. is it enough that I burn them as PAL with Nero or must I encode them
as PAL?
3. can I convert an AVI/DIVX to VCD?
thanks
Hi there,
1) That depends upon your hardware and personal preference. If your vcd player supports NTSC, then it's up to you. However, you should take into account that your TV may not be able to support an NTSC signal, and therefore will display the image in black and white.
2) In my experience, it does not matter which format you author/burn the files as. They will be played in their source format. i.e. if you burn a PAL VCD as an NTSC VCD, it will still be played as a PAL VCD...understand?
3) Yes you can, try reading the NEWBIE and/or CONVERT sections to the left
hope this helps!
Real easy question..Easiest and best avi to dvd proggy
By andrekb in forum Authoring (DVD)Replies: 3Last Post: 26th May 2011, 06:37 -
real newbie here.. help with my set up >Panasonic AG170 & Aiwa multisystem
By TurboJoe in forum Newbie / General discussionsReplies: 5Last Post: 29th Jan 2011, 12:20 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 22:47 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 23:25 -
Real noob question about DVD Movie files
By Thom Yorke in forum Newbie / General discussionsReplies: 3Last Post: 25th Feb 2009, 12:50
