Results 1 to 10 of 10
    Jan 2003
    none
    I have been coding and decoding lots of movies on avi, but there are a few movies that i cannot open with VirtualDub, the error keeps coming its says
    Couldnt Locate decompresor format xvid (unknown)
    Virtualdub requires a video for windows (vfw) compatible codec to decompress video. Directshow codec, such as those used by Windows Media PLayer, are not suitable.
    The thing is that i can open and see those video files on the Windows Media PLayer. the question is why i cannot in VirtualDub.
    Apr 2002
    The State of Frustration
    Which codecs are installed on your system?
    Hello.
  3. Member DJRumpy's Avatar
    Dallas, Texas
    You need the XviD codec. Go to http://www.xvid.org and download the codec.
    Impossible to see the future is. The Dark Side clouds everything...
    Jan 2003
    none
    im using this codecs
    ffdshow
    Ogg Vorbis DirectShow 0995
    and the
    SLDcodecpack1.5
    i have downloaded the xvid new codecs but there is no installer exe on it, this maybe be a newbie questions but thats how we learn, how can i installed on my system?
    thx for your help guys
    Oct 2002
    New Orleans
    I have the same problem...I downloaded the codec xvid.org and there isn't an installer.
    I downloaded nic's xvid encoder...but I'm having problems with windows explorer
  6. Member DJRumpy's Avatar
    Dallas, Texas
    Sorry. That link only posts the source code, which has to be compiled. Try here instead.
    http://www.divx-digest.com/software/xvid.html
    Note, you may need the 3.11 Alpha version. There is a link for it on this page too.
    Oct 2002
    New Orleans
    Thanks DJ...I installed it but windows explorer was freezing up on it so i followed advice from another forum:
    Qeef says:
    "Just use the FourCC changer (comes with the XViD codec), load the XViD code movie and put settings in both screens
    on DivX. NO OTHER!!!!
    Then click APPLY...and you can encode as ussual!!!!
    Works perfect and quality is the same."
    It works and looks great in media player...I haven't tried converting it to svcd yet...but it loads fine in virtual dub...
    Does anyone know what the FourCC changer does? I assume it only changes an extention of some kind?
  8. Member DJRumpy's Avatar
    Dallas, Texas
    Sounds like another codec package. You should be careful with these, as they tend to install things you dont' need, including spyware, along with codecs you don't need. You can get a spyware scanner here:
    http://www.lavasoft.nu/
  9. Post Deleted
    Stop Advertising
    -TGPO
  10. Member DJRumpy's Avatar
    Dallas, Texas
    DIDIDAVE, are you having dilusions of grandeur, or did you reply to the wrong post?
