Hi, i hope i put this in the correct area, if not then appologies!
I would like to extract certain parts of audio from my SVCDs (famous quotes etc). Does anyone know what software i should use to do this, and also know of any giudes with which i could use??
Thanks v much!
Copy AVSEQ01.MPG from the MPEG2 folder on your SVCD to your hard disk. Get a copy of TMPGEnc. Load AVSEQ01.MPG into the Video source box and then File>>Output to File>>Wave file. Next you need some wave editing software, such as CoolEdit or SoundForge, and you can load the wave file and easily select the bits you want.
How to increase Video Sound Levels on AVI. Files or Mpeg
By c_a_konopka in forum EditingReplies: 14Last Post: 27th Jun 2012, 20:48 -
No sound on MPEG-2 files in WMP11 after uninstalling 3rd party codecs
By brassplyer in forum Software PlayingReplies: 1Last Post: 12th Jan 2012, 03:15 -
mpeg TS files works with no sound on sony vegas what i do/??
By khalid81 in forum EditingReplies: 11Last Post: 20th Jul 2009, 10:20 -
No sound on .flv files in MPEG streamclip and others.
By seb100 in forum MacReplies: 2Last Post: 29th Oct 2008, 11:26 -
Finding and extracting single sound
By Nator in forum AudioReplies: 1Last Post: 25th Jun 2008, 03:27
