Here it go
http://www.mundolatino.ru/nivelsuperior/jo11.htm
I guess some people are to dumb to do some simple research!!! hum jarvis
Closed Thread
Results 31 to 41 of 41
Now try www.diccionarios.com and use the translation. This is a sight put up by a company from Barcelona, Spain. You know what I meant.
Ya basta y calmate.
Originally Posted by alenhard
hum on someone else's **** you pipe smoker
do your own research http://www.lcp.org/Spanglish_Glossary.htm
what are you a literalist or something?
Y creo que es para rato, porque en otro foro (doom9.org) se habla de sabotaje...
This was taken from http://forum.doom9.org
trust me, i have the logs to proof it's a synflood attack and i am a network engineer myself too so i do know what i'am talking about.
It's a bit hard to stop an attack if you're not sure who's conducting it. (we have our suspicions, and i'am building up more and more evidence as we speak!)
So far they used random hosts to attack te servers, and everytime it's a different set op ip's. But there's a patron in that set of ip's so the loop is tighting closer and closer.
__________________
<-- Official DVD2one.com team member -->
maybe you could translate this one word for word, agujero de cúlo (or trasero), which is what it means in Spain, Mexico, and most of South America.
but considering your other comments I'd say chupa me huevos pinche pendejo
Racial slurs are completely uncalled for.
dvasco,
Hang in there, the site has been & up down here recently. From attacks, and the pure volume of interested people. It'll be fixed in a day or two at the most.
Scarpad,
Perhaps :P
But that's my story and I'm sticking to it.
Backed up sevral of my DVD's withDVD2one simple to use graet quality picture the only thing i can knock is the volume is slightly low is this dvd2one??? doing this
I use dvd decrypter
dvd2one
write with nero
used diffrent media from cheap x1 to quality x4 using pioneer 105 any ideas?????
All in all though well pleased with DVD2one...Monty...!!!
I have used dvd2one on about 7 discs now and I found that even after selecting the correct audio I have gotten the comentary instead of the movie's normal audio twice.
On less than perfect discs using ritek G03 never had a problem before but since dvd2one uses the entire disk, I have been getting freezing and skipping at ending credits .
I own Nero and it has always worked before with no coasters even though there is a warning on their site about using it. I will keep Nero and use tmpgenc before I will keep Dvd2one and spend $ on another burning program that may or may not work with it.
I have since found the cure for my audio problem I process the Movie through ifoedit first no more coasters on the wrong audio since I do not use rewritable discs I have to have it right the first time.
The video looks good to me , I think the program needs some tweeking but the first version of anything has bugs.
(VHS to DVD) AVI filtering vs. straight MPEG; Post your comparisons
By darito in forum Capturing and VCRReplies: 37Last Post: 2nd Apr 2012, 04:26 -
best software to make "fair use" backups of DVDs to DVD +/-R?
By gastrof in forum DVD RippingReplies: 4Last Post: 14th Jun 2011, 14:27 -
NTSC Vhs to dvd quality
By victoriabears in forum Newbie / General discussionsReplies: 11Last Post: 11th Jul 2010, 20:31 -
How to make DVD in PAL and NTSC?
By perik in forum Authoring (DVD)Replies: 9Last Post: 19th May 2010, 14:18 -
Import BluRay, PS3, PAL/NTSC, etc. (Help Plz!)
By Startropic1 in forum Blu-ray RippingReplies: 12Last Post: 22nd Sep 2009, 22:21
