Reading peoples posts the best quality encoder seems to be Tmpgenc, of which I am a big fan, then CCE, and all others dead last. Time is not an issue, I leave the encoding on a dedicated computer overnight and while at work. Number of processes is a big issue. Not having to burn a lot of DVD coasters and fooling around with settings is also an issue.
Therefore is the quality of dvd2one so bad that it is worth going through all the processes of using multiple programs? Please post fair comparisons arguing which programs to use.
Closed Thread
Results 1 to 30 of 41
well I have used dvd2one and it does a great job, I backed up The Green Mile and that is a 3 hour movie, with great quality, also did American Pie 2, its like 1hr 40 min, with excellent quality, almost perfect in my eyes..Plus it is fast compared to other methods, Great software and simple to use.
I've used CCE for quite a while and I've encoded the same single disk with CCE and DVD2ONE. Then A/B compared them from different DVD players,switching between them on the same TV. There is practically no difference. There may be a slight graininess to the DVD2ONE copy which you will seee if you look for a difference.
I just converted a Sopranos TV epeisode disk with DVD2ONE and A/B compared the DVD2ONE copy against the original DVD and I can't see any difference. DVD2ONE works. If you spent $2000.00 for a legal copy of CCE you not very likely to like a $43.00 program that's faster and equal.
You really have to compare which one you value more. Time or quality.
The quality from DVD2One is nowhere close to what you'd get from CCE, or even TMPG.
But nothing else can encode the God Father disc 1 (8 Vobs 3 hours plus) in under 30 minutes.
As far as quality goes, I'd say it's about SVCD level. I compared 3 DVD sources of old SVCD rips I did. (I used avisynth a couple of filters, and CCE 4 pass encoding)
Training Day, Apostle, Superman IV The Quest for Piece.
The SVCD of Training Day was a great deal better than DVD2Ones. Apostle, and Superman were only slightly better.
I also put Training Day on DVD-R with CCE, there is no quality comparison between the two. After watching the original DVD, CCE's DVD, and DVD2One's, I promptly earsed DVD2One's DVD-RW.
I recently backed up Jesus Of Nazerth (385 minutes 2 DVDs) with DVD2One. It did a fairly good job on this. Not as good as CCE, but both discs were encoded and burnt in 3 hours. I did spot encodes with CCE on this DVD, although CCE looked better (not much), DVD2One was a great compromise between quality and time.
For the price of the software, it's worth adding it to your collection, but I'd use your other methods when quality is the most important issue. Of course certain films will look better or worse with DVD2One depending on the original quality, source content, and length.
I do find it unfar to compare DVD2One against CCE as they are intended for different purposes. DVD2One does what it is advertised to do, and it does it very well.
For me the AUDIO has always been a pain in the a$$. I want my 5.1!! With Tnmpeg you are multiplexing and muxing and trying to find an authoring program that will accept 5.1, only to have your finished product go out of sync. Not any more! DVD2ONE looks as good as tnmpeg to me, BUT SOUNDS 100X BETTER.
Also for dual layer discs where the movie itself is less than 4.36gb it is much faster than IFOedit. It does in 4mins what takes IFOedit 20.
Originally Posted by simmons3d
Also time is not an issue, number of processes is. I only want to have to go through a few steps, but yet have good quality.
Originally Posted by disturbed1
Readers, plz keep posting your comparisons.
"I do find it unfar to compare DVD2One against CCE as they are intended for different purposes."
It's not unfair to compare them. That's how you find out the strengths and weaknesses of when to use one vs the other. What is unfair is to expect DVD2ONE to encode with the same quality as CCE.
Someone posted that they heard TMPGenc encodes better quality than CCE. I don't recall anyone posting that. If so, then they are likely not configuring CCE correctly. However, both can produce outstanding quality DVD which is very close.
I see alot of good replies here. The truth betold there are many factors. It has little todo with the time of the movie. If the original movie is encoded at a really high bit rate that excedes 7 gig, then you may want to use the tmppg or cce methods. If its below 7 gig than you will probably never notice a difference. In the future you will have options to split the disc, do the hole disc and the ability to select the end result size wise. There is no doubt in my mind that DVD2ONE is a powerful tool and well worth the $40, but that does not mean you don't want to keep those other tools.
DVD2ONE Projects
Titanic= Good Quality
Gladiator = Good Quality
TimeMachine=Great Quality
MIB2=Great Quality
These are all better than VHS and SVCD quality. I couldn't stand the VCD quality and always questioned the SVCD quality. So I just kept all my videos in DVD quality on my HD until I finally got a DVD Burner.
Great help so far. I would like to add that I don't want to have end up redoing a backup because the first backup was subpar.
dun4cheap, you say that dvd2one is better than SVCD while disturbed1 says that it is not as good. How can we get on the same page? How can we calibrate our ratings? I do understand that the longer the movie and the more action and colors there are the worse the quality will be at 4.3GB. I think maybe we should use a movie that is picky for comparison. Gladiator maybe, not Titanic I am not a fan of love stories, or another great film with action. Maybe something with more colors too. Any ideas.
Keep posting everyone.
Originally Posted by jarvis1781
Originally Posted by dvasco
Gladiator would be a decent test film for you to try. Get the free trial and give it a whirl, then tell us what you think.
Quality is nothing more than one's thought. There is no hardcore right or wrong.
There are many members that are satisfied with the results of VCD. I know people that can't see the huge quality difference between VHS and DVD.
I think VCD in most cases is worse than VHS.
Right or wrong, it's your perception that counts.
MIB2=Great Quality
I used DVD2ONE to back up "Casino" which is a 3 hour dual layer film. I also have a tmpgenc back up and compared the two on my Toshiba 43". Very little difference, however there is a scene early in the film with lots of lights and people walking (casino entrance) and DVD2ONE actually seems to have handled it better. Less apparent blockiness. I never was all that confident in tmpgenc's 2 pass vbr.
I think that pretty much explains it. It boils down to what YOU want/need.
MIB2=Great Quality
The dvd2one trial only does 30 minutes. Not long enough to really know.
The NTSC system is very limited so it is understandable why people don't see much of a difference between VHS and DVD. TV only gives about 480x480 anyway. The quality loss in DVD is the compression. No compression with VHS. That's another subject anyway.
And yes, there is no reason to comment on movies that do not entail reencoding.
I think the Casino example was a good one.
Plz keep posting people.
Well you guys certainly have tried to make this a battle between encoders and transcoders. The Video will be better with DVD2ONE, CCE, and TMPPG encoder over any VCD or SVCD for DVD. This is due to a higher resolution and Bit rate. Now comparing to XVCD may be another story because you can have higher bitrates.
"The dvd2one trial only does 30 minutes. Not long enough to really know."
Why is 30minutes not enough to tell. What you see is what you get. It uses the same transcoding compression rate in the 30minutes as if it was the full length movie. Were you not impressed by the video quality. If not than you should go the alternate route CCE or TmpMPG..
Opinios are like A-Holes everyone has one, if you want a fair comparison , DO IT YOURSELF!! what looks great to someone might look bad to someone else, guess why Basking Robins has 31 flavors cause not everyone likes Vanilla, get my point!! there are too many variables, TV, DVD player, ambient light, etc,etc,etc. if it looks good in your set, Don't worry be happy if it soesn't then find an alternative way plaing and freaking simple!!
Is not that I do not want to give my opinion, everything I done wit DVD2ONE looks great, on my setup, not to say that you would have the same results then again i could sell you my set for about 5200.00 and then it would look awesome, but what can one expect from someone that call another human being , "pubic hair' (pendejo=pubic hair) his level of intelligence is off the scale !!!!!!!!!
In the minus sign hahaha
(VHS to DVD) AVI filtering vs. straight MPEG; Post your comparisons
By darito in forum Capturing and VCRReplies: 37Last Post: 2nd Apr 2012, 04:26 -
best software to make "fair use" backups of DVDs to DVD +/-R?
By gastrof in forum DVD RippingReplies: 4Last Post: 14th Jun 2011, 14:27 -
NTSC Vhs to dvd quality
By victoriabears in forum Newbie / General discussionsReplies: 11Last Post: 11th Jul 2010, 20:31 -
How to make DVD in PAL and NTSC?
By perik in forum Authoring (DVD)Replies: 9Last Post: 19th May 2010, 14:18 -
Import BluRay, PS3, PAL/NTSC, etc. (Help Plz!)
By Startropic1 in forum Blu-ray RippingReplies: 12Last Post: 22nd Sep 2009, 22:21
