hi
well i am still haveing trouble wit avi files. i amtrying to convert them to mpeg so i can put them on a dvd that will play in my standalone player. i am loading the file in to tmpgenc plus 2.5 and setting it up the way it is decribed in the how to info. each time it gets to 97% complete i get a streem error. here are some stats on the file
vido format
704 x 288, 24 Bits, 182421 Frames, 23.976 Frames/Sec, 87 KB/Sec, DivX codec
auto format
MPEG Layer-3,128 kBit/s, 48,000 Hz, Stereo
do i need a plugin for mpeg 3 format to use in tmpeg nc
Use virtualdub to scan the avi for bad frames. Look in the guides for how to do this if you can't work it out.
thx i have scaned it and found no errors and i scand it with divfix and found no errors i have tried to extract the audio and use tmpeg to put it back together and i still get a streeming error. i don't know what to do.
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where is my burn going wrong?
By ryan24 in forum DVD RippingReplies: 17Last Post: 21st Feb 2008, 12:25 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
