After long experience with Tmpgenc, I was indulged to try CCE. I downloaded the trial version and tried with some cut clips to test speed, size and quality.
I have read the manual and (think) am doing everything by the book.
The program seems to work as it should (no error messages and such), however everything produced is a (correct length) black movie.
I suppose I don't have a problem with codecs (no tmpgenc output caused any problem in the past) and media player doesn't complain with the mpeg2 stream loaded.
Any clues?
The more I learn, the more I come to realize how little it is I know.
What options are you using in CCE? Also, what version? Last but not least, what are you dropping into it? Is it an AVI, or frameserved?
Impossible to see the future is. The Dark Side clouds everything... -
Sorry for not catching up for a few days, I was off.Originally Posted by DJRumpy
I am trying CCE version 2.5 SP. I am using a DivX 5.02 file encoded at 10mbps CBR. I tried quite a few different options, but since I could not get any output, I reverted to the basics: MPEG-2 CBR @ 6mbps, selected to output elementary streams and produced a video and an audio stream.
The result (for a full length movie) was 130 MB of black frames. I have also tried VBR (2 passes) and MPEG-1, with the same results.The more I learn, the more I come to realize how little it is I know. -
Sasi, this is the one you already solved isn't it?
yep!
Crop/Remove black bars without re-encoding?
By agent154 in forum Blu-ray RippingReplies: 55Last Post: 22nd Aug 2015, 20:06 -
How to put black colour on screen without re-encoding?
By swalih in forum EditingReplies: 6Last Post: 16th Feb 2012, 03:44 -
encoding black border or not ?
By miss in forum Video ConversionReplies: 1Last Post: 3rd Sep 2009, 09:27 -
Encoding to .FLV but just black in converted file??? Help me please!!!!
By mkettle in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2009, 18:32 -
an entirely black movie i think
By jboyd in forum ffmpegX general discussionReplies: 9Last Post: 11th Nov 2007, 13:50
