ok i tried to encode a xivd avi to a dvd (pal) useing tmpgenc i took the wave out the xvid useing avi2wave, but it is still out ov synck
these r the settings i encoded to DVD PAL (MPEG-2 720x576 25fps VBR 5100kbps, Layer-2 48000Hz 384kbps)
any 1 got any idea wot i done wroung?
the wave file was only a 115mg could that have sumit to do with it
Did you use TMPGEnc audio encoder, or an external encoder?
Hello. -
not o sure wot u mean? wot i did was load the xvid into tmpgenc then i loaded the wave file then i just hit start but like i said when it was finished it was outa synck
Go Environmental settings-->Audio Engine. Under this tab is where you should install external audio tools like TooLame, etc. They are better than TMPGEnc's audio encoder.
Hello. -
werc would i get this toolame i tryed in the tools section on here but the link was not working, also when i do get do i put in the tmpgenc folder or run it in a diffrent dir
You install it in its own directory, but tell TMPGEnc where to find the toolame.exe file. Click here.
Hello. -
thank for all the help it worked great,thanks to u i have just managed to encode my first dvd
