Im trying to convert A DIVx AVI into VCD using TMPGEnc Plus Version 2.510.49.157 the problem is im not getting any Audio. The settings im using are
-Template: VideoCD(NTSC).mcf
-Rate Control Mode: 2-Pass VBR(VBR)
-Motion Search Precision: Highest Quality(Very Slow)
-Source Aspect Ration: 4:3 525 Line(NTSC)
-Stream Type: System(Video+Audio)
The file created is A MPEG-1 352x240 29.97fps VBR 1150kbps, Layer-2 44100Hz 224kbps
Does anyone know why im not getting any Audio? If so please post or
E-Mail me Thanx.
have you tried to encode the audio and video seperatly. then just combine the two files useing mpeg tools...
No I have not tryed that but why should I have to do that it should just do it because I have Video+Audio selected
~~(scratches head)~~
Seems to me I remeber reading in the TMPGEng documentation that it will not convert audio if it is not already at certain pre-set bitrates. Some limitation in the program that only affects AVI source files.
Can't quite remeber what it was but I suggest reading the DOCs carefully about audio conversions.
Good Luck
Only 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy -
I too am having the same problems.. Encoding divx's and i get the picture but no audio.
The audio file is presents and is (for example) 500mb but when you play it in any kind of audio player no sound comes out..
I have at the moment started to use Canopus Procoder and with this I have no problems at all.. The sync of the movie and sound are perfect..
If you find out what is causing this problem in tmpgenc then i would be grateful if you could email me with the solution..
Cheers
Djinn -
Because TMPG does not handle compressed audio well. If you want to guarantee sound, ALLWAYS extract the audio first as uncompressed .wav, and input that to TMPG. The convert section will tell you how.Originally Posted by Sergio Fernandes
TMPGEnc Authoring Works 5 Version & HD-PVR Question
By TBoneit in forum Authoring (Blu-ray)Replies: 25Last Post: 18th Nov 2015, 17:20 -
Tmpgenc Authoring Works Version 4.0.7.32 - November 9, 2009
By juliocesar in forum Authoring (DVD)Replies: 3Last Post: 27th Nov 2009, 05:05 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 09:25 -
How to encoder file with AAC/AC3 in TMPGEnc Xpress 4 (English version)
By roc255 in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2008, 16:57 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 02:19
