Need help...I tried running ADVDInfo to check what kind of DVD-R media that I have and I am getting an error message ("Could not create Device List"). Does anyone know what that means (and is there a better software to check if the DVD-R media that I have is Ritek)?
I installed ASPI from adaptec using the following command (run install.bat XP32). Is the XP32 correct setting for a Compaq Presario? Any tips would be appreciated.
Results 1 to 1 of 1
