Salut!
ive experienced problems with a downloaded video file coded with the xvid codec (it says so...)
when im trying to watch it, it is green at the beginning and turns into a lot of blocks (so it is absolutley unwatchable...)
i have win xp, nimos codec, the divx 502 and of course the xvid codec installed. i tried several players like winmedia, zoomplayer, power dvd nothing worked.
with my other pc (win98, all the codecs) i dont have those problems. the same videofile runs smoothly and with no green or "blocky" image.
what is the problem? does it depend on my video card or the driver (msi gf4 4200, detonator 41..)???
pls help!
Download this and then try to play your Xvid AVI:
http://ffmpeg.sourceforge.net
FFMpeg. -
Also install: divx 3 &4. And for Xvid: try Ffdshow.
D.C. 8) -
I had this problem. I uninstalled Nimo and installed stand alone XviD. Problem solved.
thx 4 ur help!!!
i deinstalled nimo and installed ffdshow now everything runs perfect
Xvid Sync Problem
By Peru in forum AudioReplies: 4Last Post: 21st Feb 2011, 13:15 -
Problem with convertion to xvid...
By zovx in forum Video ConversionReplies: 11Last Post: 11th Feb 2010, 07:43 -
MKVTools and Xvid problem
By Geiger9 in forum MacReplies: 5Last Post: 18th Jun 2009, 16:34 -
Problem with XVID
By s2dat in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2008, 12:25 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
