  1. Ok, I am all new at this. This is what I wanna do. I have a sony video camcorder. And i want to take that video feed and put it on my computer, i'll be using my WinTv adapter to transfer the feed over to my co,puter in AVI format (which is best format, 32 bit RGB, 15 Bit RGB, YUY2, BTYUV, YUV9, YUV12) Then I'm going to edit it in Adobe (all my editing software is adobe) Then save it as a compressed file, APVC i think is what I did before. Then I wanna take that file and burn it to a cd-r and have playback in a DVD player. How can I do that??? Please Help
    Aug 2001
    San Diego
    When you came to this website, did you make an effort to totally ignore all the How To's that appear in the column on the left hand side?
    They are there for a reason. So that people who are new to all of this have a good set of reference materials to read and learn from. They cover everything it is that you want to do.
    I suggest you read the "Author" , "Capture", and "Convert" How To's, and then if you still have questions, you'll find that the people here will be more than happy to help, but nobody likes it when someone is too lazy to even take advantage of the resources that are offered.
    Oh, I also suggest you read the "What Is" on VCD's.
  3. Yes, i did read all of that and I tried to burn a vcd on a cd-r and play it back on a dvd and it did not work.....
